Speedometer Gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2013, 12:31 PM
57halfton's Avatar
Speedometer Gear
I have a 350 Turbo Hydro out of a 70 Chevy Impala in my pickup and have been having speedometer problems. What I was wondering is what is the speedo gear made out of that is on the tailshaft inside the extension housing, is it plastic or metal ? Does this gear ever cause problems ?
Thanks , Gene
Old 02-10-2013, 01:38 PM
LATECH's Avatar
Yes it is plastic, and yes they do wear out and cause an ittermittent speedometer .
You can replace it easy,
1 Pull drive shaft
2 pull 4 bolts from tailshaft housing
3 grab hold and yank housing off
4 see gear...depress clip...slide gear off...install replacement
5 reinstall parts in order they came off.
The gears are colored , some grey, green , blue etc.Most of the time that will be what the parts guy needs to get the correct one. Dont go to autozone or advanced...they wont help you.
Go to a place that rebuilds transmissions or go to the GM dealer, they can help
or get one from http://www.transmissioncenter.com
Fact is stranger than Fiction
Old 02-10-2013, 02:41 PM
57halfton's Avatar
LATECH , WOW outstanding answers to my questions , Thank you so much.
One more quick question, When I remove the tailshaft housing am I going to get much transmission fluid out of it ?
Thanks again , Gene
Old 02-10-2013, 02:52 PM
LATECH's Avatar
Very little if any.
speedometer gear hyde Transmission - Rearend 1 11-18-2012 09:28 PM
Speedometer gear Dtimekw Transmission - Rearend 4 05-03-2012 10:09 AM
speedometer gear Blob Transmission - Rearend 3 07-17-2005 05:22 PM
speedometer gear 1986 Trans am Transmission - Rearend 2 10-26-2003 03:00 AM
Speedometer Gear Change ? bigjoedo Transmission - Rearend 3 07-04-2002 07:52 PM
