speedometer gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2006, 09:43 AM
Drive Fast, Take Chances!!
speedometer gears
I know i have asked this question before but i keep getting different answers from everyone. i have a 86 GMC k1500 with a NP 208 transfer case
I changed my rearend from 3.08 to 3.73. now my speedometer is off obviously. I looked at a set that my buddy has for 3.73 and tried to order that set from my local Chevy dealer and the inner gear is discontinued. Can I make just the 21% change with the outer gear without the gears binding up?
Old 12-16-2006, 08:59 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Don't know about the factory gears but you can go to your local speedo repair shop (most medium to large cities have them) and get a gear ratio add-on box. They will install a little black box in the speedo cable line with the exact conversion ratio you need and issue you a laminated speedo calibration certificate good at any Highway Patrol speeding violation stop. Cost used to be in the ~$50 range.
Help Speedometer Not Working (at all) phebbler Transmission - Rearend 7 08-01-2006 02:13 PM
Tranny gears or rear gears? strummin67 Transmission - Rearend 4 06-12-2006 11:17 AM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 02:01 PM
Speedometer Information. M&M CUSTOM Transmission - Rearend 0 04-03-2005 09:47 AM
how to change gears.... jackflash Transmission - Rearend 4 04-10-2003 04:47 PM
