Speedometer Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2007, 12:20 PM
Speedometer Help
Im not sure exactly were to put this and I havent found any help yet. Anyway I have a 96 Geo Tracker and if I am going under 30 MPH the speedometer needle isnt a fluid motion like it should be it jumps around. However when I get above 30 MPH its fluid the way it should be and works fine till I drop below 30. Any help on fixing this would be appreciated.
Old 08-07-2007, 12:49 PM
Speedometer Help
On your model the speedometer and the vehicle speed sensor (vss) are made
together. To test the vss you will need to first disconnect the neg. cable and
remove instrument cluster. Connect an ohmmeter between the vss and
ground terminal on the back of the instrument cluster and insert a flat
screwdriver into the speedometer cable connector. Rotate the screwdriver
the ohmmeter reading should alternate between 0 and infinity 4 times for
each revolution of the speedometer head. You will need to replace
speedometer if vss does not test as described. Hope this helps you
good luck!
Electric Speedometer Senders oldcarguy36 Electrical 10 05-08-2010 02:53 PM
speedometer with its own mind???? Old School Nut General Rodding Tech 15 06-06-2008 04:10 PM
Speedometer fred56 General Rodding Tech 5 01-17-2007 02:25 PM
Help Speedometer Not Working (at all) phebbler Transmission - Rearend 7 08-01-2006 01:13 PM
Speedometer Information. M&M CUSTOM Transmission - Rearend 0 04-03-2005 08:47 AM
