Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
Closed Thread
  #1
Old 04-03-2005, 07:47 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Overqualified Underacheiver.
 M&M CUSTOM's barnstar
Speedometer Information.
This thread is meant to answer as many questions as to:
How do I correct my speedometer?
Why does my speedometer needle wobble?
I just changed my rear-end gears why is my speedometer so far off?
What gears do I need to correct my speedometer?
JUST REMEMBER THIS:
(Q) I got an instrument cluster from a wrecking yard. Can I use it in my project vehicle? Can it be reset to the mileage I want?
(A) It is a felony in most states to tamper with odometer readings, honest people in the business or repairing such mechanisms are NOT willing to risk it for the sake of providing you with a counterfeit "low mileage" car -- no matter how nice you are.
This has been a project that I wanted to work on for quite a while, I was going to hold off until I got things worked out the way I wanted, and to make it as easy as possible, BUT here we are with little to go on.
However, you are allowed to repair the speedometer mechanicals to allow the reading to be as correct as possible, the ODOMETER is the "rolling" number counter that tells the vehicle operator how many miles the vehicle has been driven, the odometer is a PART of the speedometer.
The speedometer is a mechanical calculator comprised of a drive gear, a driven gear, at least one cable and the speedometer head. The drive and driven gears can be changed to allow correct readings in tire and axle gear changes, but to a certain extent without an additional gear ratio adapter.
Newer computer controlled vehicles speedometers are electronic units that use specific parameters, signals, and calculations for that specific vehicle to show the correct speed, I WILL NOT COVER THESE AT THIS TIME- UNLESS SOMEONE WANTS TO HELP.
Mathematical equations related to gearing:
Ratio = (rpm x tire diameter) divided by (mph x 336)
RPM = (mph x gear ratio x 336) divided by (tire diameter)
MPH = (rpm x tire diameter) divided by (gear ratio x 336)
Tire Diameter = (mph x gear ratio x 336) divided by (rpm)
Online calculators:
This one tells you the size and MPH differences when switching tire sizes.
Corvetteactioncenter.com's Speedo Calibrator
I have used this link frequently in the past.
This is a tire size comparison calculator.
This link does the math for finding out MPH with many parameters you can change.
A MPH Calculator from RPM and Gearing
This link gives some ratios with referenced tire sizes, and part numbers for correcting speedometers in a Jaguar/Chevy V-8 swap.
Chevy TH-350/400/700R4 in a Jaguar.
A freeware RPM calculation program I found this morning.
This tells what gears are needed for correct speedometer readings, but DOES NOT cover all transmissions.
Bowtie Overdrive's Speedo Calculator.
This link also lists gears available.
TCI's Calculator, this requires you to already know what drive gear you have.
This link shows available speedo gears, gearing reducers and recommended combinations for correct readings.
Speedometer parts and calculations.
Try the search link above (it has a small dropdown arrow immediately next to it and search for what you need through the 14 pages of results. Just type in "speedometer". This subject has most likely had your particular question covered in the past. I will eventually have links to the most important and relevant information for almost anyone to find what they need.
I will have A LOT OF INFORMATION when I get this done, however long that may be.
Closed Thread Back to top
This discussion has been added to the Transmission - Rearend Discussions category of the Hotrodders Knowledge Base.
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Speedometer Information."
speedometer with its own mind???? Old School Nut General Rodding Tech 15 06-06-2008 03:10 PM
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 12:37 PM
Speedometer Problem - Not sure where to put this? Fragzem Transmission - Rearend 6 02-04-2005 01:09 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 02:15 PM
700R4 - Speedometer chev38 Transmission - Rearend 10 05-06-2004 07:00 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
