Speedometer not working??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2004, 10:43 PM
Mightymouse's Avatar
Chevy SS
My speedometer stopped working, its still conected into the tailhouseing on the transmission (Th350) But it aint working and it makes a clicking noise when i get the car moveing, sometimes if i play with the cable it will work for a minute or 2 then quit again
Anybody got any idears of what it mite be??
Old 06-23-2004, 11:00 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Pull the cable out of the housing, inspect both ends, if it looks good, put one end in a vice and stretch it out and measure it, then give it a pull and stretch it about a 1/2 inch longer, apply some white grease and re install it. Good Luck.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 06-24-2004, 04:41 AM
BarryK's Avatar
[QUOTE]Originally posted by troy-curt
[B]Pull the cable out of the housing, inspect both ends, if it looks good, put one end in a vice and stretch it out and measure it, then give it a pull and stretch it about a 1/2 inch longer, apply some white grease and re install it. Good Luck.
Troy
Had no idea! This could be done!
Was just about to rip steering column out to pull speedo!
Cable, I can pull in 1 minute.
Thanks Troy!
