speedometer ouput pluged? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2005, 07:21 PM
i bought a vdo speedo and a vdo sending unit to be used with a gm tranny. so today i go to screw in the sending unit only to notice that the output on the tranny where the factory cable would go has what looks like a soft plug in the whole, there is no threaded thing for me to screw the sending unit on to. So i go over to another trany i had laying around (77' olds th350) it has the output thing i need, but the hole it goes in is about 2 or more inches in diameter and the other tranny's hole is about an inch in diameter?. Should I remove the plug? would a local store(napa, pepboys...) have a output thing I am looking for?
any help would be great
Old 06-16-2005, 08:11 PM
Crosley's Avatar
Wiki Edits: 1659
more information please
Make and model of the tranny you want to install the speed-O hookup?
Old 06-17-2005, 07:09 AM
its a gm th350, i dont know what it cam out of since i bought it off a friend
Old 06-17-2005, 07:56 AM
Crosley's Avatar
Wiki Edits: 1659
IF both trannys are t-350 , then one has a buick / pontiac style tail housing with large speed-O hole for the speed-O bullet.
the small speed-O bullet tail housing is a chevy piece.
You cannot mix and match these speed-O parts. the plastic gears on the out put shafts of each unit look the same diameter, they are not
speedometer with its own mind???? Old School Nut General Rodding Tech 15 06-06-2008 04:10 PM
Speedometer Information. M&M CUSTOM Transmission - Rearend 0 04-03-2005 08:47 AM
Speedometer Problem - Not sure where to put this? Fragzem Transmission - Rearend 6 02-04-2005 02:09 PM
Speedometer gear housing problem guba_unus Transmission - Rearend 1 01-09-2005 07:08 PM
700R4 - Speedometer chev38 Transmission - Rearend 10 05-06-2004 08:00 PM
