Speedometer Question
I'm looking for a spepdometer that includes turn signal and hi-beam indicators for my 35 Ford.
I originally was going to use Mooneyes gauges and insert small indicator lights on the dash, but an "all-in-one" unit would be a cleaner install. Thanks. |
Doc here, TRY Dolphin gauge clusters.. However, I personally feel..IF you want to go mechanical, a 56 Chev Dash Cluster (modernized) would look primo in there... Doc
Aftermarket Solutions Electronic & Electrical Innovations |
why not drill your gague and use small leds for indicators?
Shane |
Doc here, I've Done that before..It looks Ghetto, and hard to see.....sounds good when you think about it, but once in you'll be WAYYYYYYYYY disapointed.. There IS a way to do it without looking Ghetto, Cut a large Rectangle Hole for each, (about 1 x 1/2) install 3 , 12 volt "Bright" white L.E.D.'s and a green filter lenses over each hole, and a blue one for High/Low...That looks more Pro done.. I've used them for shift point lamps on the faceplate with mixed results.. ![]() Doc
| supercharger.... | 73monte | Engine | 16 | 07-24-2010 10:27 AM |
| 383 stroker | 73monte | Engine | 10 | 12-05-2009 08:02 PM |
| GPS Speedometer | rcrfly | Hotrodders' Lounge | 15 | 09-13-2006 01:24 AM |
| Ignotion Set-ups | Native Gearhead | Engine | 8 | 11-29-2003 01:20 PM |
| nitrous | 69BiRd | Engine | 2 | 11-28-2003 10:33 PM |
