speedometer recalibration
I have changed tire size,and gear ratio on my 86 t-bird. I know the % of error, how do I change speedo readout. There is a box on the side of tail shaft where the old cable drives used to be, but there is only 2 wires coming out. Is there a gear in there I can change? 86 Tbird w/ aod trans . thanx
On the Chevrolets with electric speedometers ... you can change the chip prongs up and down combinations and get the results ...
Maybe the same on a Ford ... I do not know ... |
speedo calibration
A Ford fix like a GM? that would be nice for a change.
speedo calibration
I don't know what the original gears but I scored a 9
I"m not sure what the original gears were, but the new housing I got is a 9 inch that has a 3.90 gearset. I've gone from 26 1/2 " tall tires to 29" tall and the speedo definitly reads slow. 64 is around 70 according to the odometer difference between mile markers on a straight Interstate section for 5 miles. Thanx, I'll be able to compute the proper gear due to the shared info. Thanx again. |
http://novaresource.org/speedo.htm has a formula you can use with your gear ratio & tire diameter
http://tciauto.com/tech_info/speedo_gears.htm has some calculators |
| speedometer with its own mind???? | Old School Nut | General Rodding Tech | 15 | 06-06-2008 04:10 PM |
| Th400 electronic speedometer / speed sensor Chevy truck | Twistedwrench | Transmission - Rearend | 2 | 08-05-2006 10:43 PM |
| Help Speedometer Not Working (at all) | phebbler | Transmission - Rearend | 7 | 08-01-2006 01:13 PM |
| Speedometer Information. | M&M CUSTOM | Transmission - Rearend | 0 | 04-03-2005 08:47 AM |
| 700R4 - Speedometer | chev38 | Transmission - Rearend | 10 | 05-06-2004 08:00 PM |
