speedway 1.3 ratio breakin rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2010, 04:32 PM
speedway 1.3 ratio break in rockers
i just got my break in rockers from speedway and noticed that they are nearly a perfect copy of my scorpion rockers. even the fulcrum bearings both say made in the usa. anyone know if these are for sure made by scorpion. if so they are about 20 bucks cheaper. doesn't sound like much but these baby's are NOT as cheap as you would think break in rockers should be. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
Old 04-14-2010, 07:54 PM
ericnova72's Avatar
More for Less Racer
Why should they be any cheaper?? Just cause you don't use them for long on each engine?? Same amount of work went into making them.
They do look like they are made by Scorpion from the pics you posted. Several of the rocker arm makers will make house brands for other companies.
Old 04-14-2010, 08:04 PM
I guess when you put it that way it makes sense. At least there USA made. I was worried I was going to get some offshore junk by saving a few bucks but lucked out
Old 04-14-2010, 08:11 PM
ericnova72's Avatar
More for Less Racer
Speedway is usually pretty good about quality
roller rockers or roller tip rockers Jared Engine 18 08-01-2007 01:18 PM
Low Ratio Break-in Rockers?? camaroman7d Engine 5 01-22-2004 03:16 PM
Cheap Roller Rockers 72Olds442 Engine 3 10-27-2003 09:11 AM
split ratio rockers layinitdown Engine 4 04-11-2003 10:39 AM
1.5 vs. 1.6 ratio rockers Jared Engine 1 03-11-2003 08:12 PM
