Speedway four-bar question
I have a Speedway four-bar for the rear of my Model A...
http://www.speedwaymotors.com/Rear-S...Kits,3400.html ....Photo of unit (Enlarge the image).... After getting the kit I notice the bracket construction... The rear axle bracket looks fine, "sandwich style" bracket, as they say, which puts the bushing bolt in double shear. However the front frame bracket is not "sandwich style" but has tubes in it for the bolts, and the bushing is outboard of the bracket on the bolt in single shear. Not the strongest setup in my opinion. But is it OK? Anyone used this set? Any problems or comments? |
I have single shear both front and back on my sedan delivery.
Front: Rear: However, this is not going to be any sort of strip demon. Nor do I have much cause anymore to burn off a set a tires. Just a basic cruiser. If you have intentions of putting a lot of horsepower into the car or you like to abuse the throttle quite often, you might want to design some brackets with double shear. Never hurts to error on the side of more strength.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
cboy's stuff is nice to look at, isn't it.
| supercharger.... | 73monte | Engine | 16 | 07-24-2010 10:27 AM |
| 383 stroker | 73monte | Engine | 10 | 12-05-2009 08:02 PM |
| Ignotion Set-ups | Native Gearhead | Engine | 8 | 11-29-2003 01:20 PM |
| Hi All I just Joined, Questions Re:454 rebuild | Gay-Shark | Engine | 8 | 11-29-2003 10:25 AM |
| nitrous | 69BiRd | Engine | 2 | 11-28-2003 10:33 PM |
