-   -   Speedway's Bolt on Mustang II IFS (http://www.hotrodders.com/forum/speedways-bolt-mustang-ii-ifs-221592.html)
gllooki 07-12-2012 10:45 AM
Hi all....has anybody used Speedway's Bolt-on crossmember and IFS for a 1947 - 1953 Chevy Pickup. Problem with this system is that if requires modifying the frame by cutting a C notch on both sides and triming about two inches off of the radiator crossmember. Seems this would weaken the frame......any thoughts??
OneMoreTime 07-12-2012 11:43 AM
Welcome to the board..moving on to the proper forum///
BTW..once the crossmember is in then you box that area and it will not be going anywhere...
Sam
gllooki 07-13-2012 08:19 AM
Thanks Sam....was just a little concerned about wacking on a frame not engineered for 520 HP SB. Did find another bolt-on at Chassis Engr that requires no frame mods, but has no boxing and uses struts instead of coil overs.
Leaning toward Speedway's at this point.
Gary
