Speedway's Bolt on Mustang II IFS - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2012, 10:45 AM
Hi all....has anybody used Speedway's Bolt-on crossmember and IFS for a 1947 - 1953 Chevy Pickup. Problem with this system is that if requires modifying the frame by cutting a C notch on both sides and triming about two inches off of the radiator crossmember. Seems this would weaken the frame......any thoughts??
Old 07-12-2012, 11:43 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Welcome to the board..moving on to the proper forum///
BTW..once the crossmember is in then you box that area and it will not be going anywhere...
Sam
Old 07-13-2012, 08:19 AM
Thanks Sam....was just a little concerned about wacking on a frame not engineered for 520 HP SB. Did find another bolt-on at Chassis Engr that requires no frame mods, but has no boxing and uses struts instead of coil overs.
Leaning toward Speedway's at this point.
Gary
Mustang II IFS - Washers on lower through-bolt? SinistrV6 Suspension - Brakes - Steering 12 03-30-2011 09:08 PM
Mustang II IFS chevykid33 Suspension - Brakes - Steering 4 03-20-2009 07:53 AM
Later than Mustang II IFS moparist Suspension - Brakes - Steering 9 06-09-2006 07:09 PM
bolt in IFS jamn50 Suspension - Brakes - Steering 1 12-03-2004 09:15 PM
mustang II ifs fishingindeep Suspension - Brakes - Steering 7 11-12-2003 04:57 PM
