spi 2k primer activator - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2006, 10:58 PM
What is the best way to store the spi 2k primer activator after you open it?
Reason I ask is, my activator hardened in the can, of course it was a pretty long time (months) from when I used it initially and when I tried to use it again. I'll need to order some more activator so I can continue my priming. I thought before I get some new activator and open it and then let it harden again, I'd ask about storing it for extended times.
Is there another brand of activator that I might be able to use that I could get from my local paint store (no they don't carry SPI)?
Thanks
Old 11-12-2006, 05:12 AM
BarryK's Avatar
The jobber in MS you bought the primer from just have them give you a new hardener and bill me, they will know what to do.
Activators are best stored at a stable temp like in a basement or closet as what needs to be avoided is a garage situation where it is 90 today and 40 next week and then back to the 80's.
The biggest harm to an activator is opening the can and not getting the top on right away and or sealed good but some things are out of your control also like the humidity the day you open the can (higher the worse) and how much activator you use that day.
If the can is left a 1/4 filled then the can can hold more air then if you only used say a 1/4 of the can and the can is still 3/4 filled.
Bottom line is an activator may store after opened 3,4 or more years and I have seen them go bad the next couple of days also.
Old 11-12-2006, 08:32 AM
Thanks for the info Barry. The guy I bought from does comes to Vicksburg on occasion, I think about once or twice a month but I need to get some activator by next weekend. I primed with your epoxy and was getting ready to use the 2k when I found the activator hardened. Could I call Baker tomorrow and buy a can of activator from them and get them to send it to me by the weekend? I know they and you like us to use local distributors and I will when I order some more of your primer and base coat. I appreciate the offer of you covering the bill on the activator but I wasn't trying to get another can free, I just wanted to make sure I knew how to store it after I open the next can.
Thanks again for your customer care, especially taking your time to answer a question from someone that doesn't use or buy a lot of paint. Other suppliers, take notice, this is how customer service is suppose to work.
Thanks
Old 11-12-2006, 08:53 AM
BarryK's Avatar
I'd rather you did call Baker on this then bother the jobber for a freebie.
Call Baker and tell them to bill me, not an issue as I feel its more my fault then yours.
1-800-476-3006
Edit:
I have emailed Jeff and Terry but did not have your name so told them from Vicksburg so just ask for either and they will handle.
Old 11-12-2006, 10:53 AM
Irelands child's Avatar
Cutomer Service
As far as I'm concerned Barry IS customer service personified - when I call him I know exactly what I have to do when we are done talking - especially since I'm a rank amateur using the new products on the market today.
Dave
Irelands child
Old 11-12-2006, 08:22 PM
Thanks Barry, I'll give them a call tomorrow. I still don't feel like you should cover this, it was probably my oversight in storing the stuff.
Thanks again
Donnie Cool
Vicksburg Mississippi
Old 11-12-2006, 09:19 PM
texastomeh's Avatar
BarryK,
OLDCARGUY36 sorta' opened the door on a question that I've been wanting to ask.
As I've said several times in other posts - I'm planning on doing my '53 Vette Replica in SPI products top-to-bottom. As I'm getting closer to paint and wanting to start shooting some test panels, I've started looking seriously at purchasing the various sealers, primers, base, etc. (will be buying from your local guy in Garland, TX). As with most products it's cheaper per ounce to by in the larger sizes (Gal. vs Qt., Qt. vs. Pt., etc.).
I would appreciate your thoughts and recommendations (certainly don't expect you to guarantee) re "shelf life" of (for instance) buying a gallon (or quart or pint) of epoxy sealer, 2K primer, base, clear, etc. and once it is opened storing it in multiple smaller containers. The guy in Garland (as does most paint outlets) has various sizes of new metal cans and lids.
Sure, you would probably waste a little paint, but it seems that keeping free space (aka air and moisture) in the can to a minimum and not exposing the paint every time that you got ready to use some would be a good thing.
Am I off base in my thinking? I welcome your thoughts and advice.
texastomeh
Old 11-13-2006, 05:41 AM
BarryK's Avatar
The idea is great but it is really not worth the hassle.
We pretty much know that cans of activators that are unopened from the factory have a 1 in 18,000 chance of going bad and normally this will be from a pinhead hole in the welding of the can.
As far as opening a can and then it going bad as it sets we know we replace one about every 23,000 cans so actually if you seal everything good after you open the can the odds are more in your favor of the product staying good then buying a new can from us.
That sounds bad but we have no control over the can manufacturer and they can have equipment problems as well as anyone else.
I would not worry about it at all, just keep everything sealed and in a stable temp area and should not have any problems.
Old 11-13-2006, 06:37 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
dont throw away that old ice box. i have several. great for sandpaper, hardners . i even have one for my welding stuff. keeps them at a good temp and out of the moisture. when i buy paint i have it poured into qrt cans. easier to mix , less mess.
Old 11-13-2006, 11:15 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I still find adding marbles to the can to displace the air
works pretty good for making it last!!!
Old 11-13-2006, 11:34 AM
texastomeh's Avatar
But, JC - according to my wife, I've lost all my marbles!!!! Maybe instead, I could use some of the rocks that she says my head is full of.
Thanks for the advice Barry.
SHINE - I like the suggestion about the old refrigerator.
Old 11-13-2006, 12:16 PM
I have herd that pumping in a gas like argon will displace the oxygen. have never done it pesonally. Ed ke6bnl
Old 11-13-2006, 12:25 PM
Argon will probably work but nitrogen is normally used - just as long as the gas contains no or very little oxygen - the container has to be air tight.
Irelands child
Old 11-13-2006, 03:15 PM
BarryK's Avatar
Argon is perfect if you have it handy as its very heavy.
Nitrogen is used in packing the hardeners because it is cheaper.
Argon would actually be better.
Still this is overkill for a bodyshop and I don't think its worth worrying about.
Old 11-16-2006, 02:21 PM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
I've had pretty good luck with hardeners, don't think I've ever had any gel on me. What I like to do is get the lid back on the container immediately, even if I'm going to make more in a bit. Then when I'm done with the container, it gets capped good and inverted for a few seconds, the theory being that any tiny air leak will be filled by hardener which will gel up later since it is in contact with air. That seals up the container and protects the rest of the hardener. I do this with paint cans too, and it seems to work OK.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-22-2007 12:32 AM
Gallon of SPI 2K Primer Ruined starquest Body - Exterior 44 02-24-2006 11:41 AM
primer question 347mustang Body - Exterior 3 07-05-2005 09:17 PM
"Basic of Basics" What are the new paints all about? Centerline Body - Exterior 0 07-26-2004 07:43 AM
