Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spi ??? Base coat
Old 01-17-2013, 09:53 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Originally Posted by gearheadslife View Post
looked over their site..
saw primers/sealers and clears, and 3 basic color(base coats)
what are you guys using for a mixed base?
as we know some "systems" don't play nice together..
For my next 2 jobs, it will be SPI through out, the job after that will not be SPI through out...SPI doesn't have the colors...Yes sometimes different systems don't play nice together.....This is usually the case if you use a different manufacturer's catalyst or even reducer than the original manufacturer suggested. If you use SPI Primer, prep it properly, use Dupont base (mixed properly and allow proper flash times) and PPG clear (mixed properly with proper flash times between coats) there shouldn't be a problem related to using different branded products....If there was a problem doing this...we should all use exactly what Ford, Dodge, GM or whatever was originally put on for paint from the factory to do a repair or a blend after a vehicle has been involved in a collision...and I don't believe that there is one body shop that does...I've sold PPG, Dupont and Nexa to GM dealerships, Ford dealerships, etc...they all seem to work and play nice when they are used properly.
Ray
