SPI clear - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2012, 05:32 PM
SPI clear
well after reading some info on here and a few on line searchs im gonna try some of this clear called them today. seemed like a decent fellow too. since they dont have a jobber in my area i asked them about that also. i know about 25 body shops in this area that might want to try this product mix is 1.1 ratio and i got the slow reducer for up to 90 degrees since im not ready to paint the casket yet but almost.
Old 05-04-2012, 06:14 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
You cant go wrong with spi clears.. Sounds like you purchasd the Universal that mixes 1:1.
Happy Spraying.. You will be hooked now lol
Old 05-04-2012, 09:17 PM
67Elcamino's Avatar
I should had asked this question before as I shot some universal clear but I was wondering whatbthe shelf life on this clear is and if i shake it and itbhas bubbles in it can it be shot that way? I dont have much experience shooting other clears but shot today with my Iwata Ls400 and seems to lay nice. Whats the trick for shooting clears over silver metallic? I cant seem to see how its laying out or how much material im shooting. I have a new respect for those who can lay down metallics perfectly. It took my 5 coats to get rid of the tiger striping
Old 05-05-2012, 02:12 AM
i think spi is good stuff
Old 05-05-2012, 09:33 PM
deadbodyman's Avatar
Wiki Edits: 11
My favorite clear...
The trick to even metalics silvers and golds especially is to criss cross your pattern...If you go front to back on the first coat go side to side on the second,then incress the pressure and hold the gun about 12"-24" and fog on two diagonal coats the first going one way and the second going the other ,making an X you'll never see a tiger stripe again...I usually reduce the base again by half as much for these two fog coats,half a cup should do the whole car..
Old 05-06-2012, 07:02 PM
yo dead thanks for that little tip cris/crossing ill have to try that when i paint my casket
Old 05-07-2012, 05:58 AM
Wiki Edits: 11
A lot of guys say its not needed but the one time I thought it looked good and didnt do it I got the stripes ,so I just do it every time..
Old 05-07-2012, 08:51 AM
cyclopsblown34's Avatar
Colorsanding painter
I'm with DBM, I don't take any chances. I do a fog coat or two any time I spray metallic or pearl.
Old 05-10-2012, 06:20 AM
The air bubbles are nothing to be concerned about, when the paint goes through the nozzle on the gun it will be so atomized there will be no air bubbles.
SPI clear retwelder Body - Exterior 9 03-23-2012 06:43 AM
SPI clear mitmaks Body - Exterior 28 11-22-2010 03:43 PM
SPI clear 65ELCMO Body - Exterior 7 03-11-2010 05:05 PM
Which SPI Clear?? 62galaxiguy Body - Exterior 2 09-21-2009 09:19 AM
spi clear malibu350 Body - Exterior 21 11-07-2005 12:23 PM
