SPI clears and primers question.. - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 11-18-2005, 09:41 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Why I don't do much cold weather work.
You can play with activators and such but the bottom line is it's cold and stuff get's REAL SLOW. Heat cure's just seem to be bad news as it skim's over and STILL has to finish which just prolongs the process. I've had MORE problems trying to speed things up than IF i'd left them alone.
Bottom line is,
Winter SUCKS.
  #47 (permalink)
Old 11-19-2005, 07:04 AM
adtkart@aol.com
One of the unfortunate things about living in a cold climate is that you have to pay for heat to make up for Mother Nature.
I sprayed the Universal Clear a couple of weeks ago. I had the temp at about 80-84 deg while spraying and for 4 hours after. That may have been a little higher than what you want to pay for, but worked for me. I finished spraying at 5 P.M. and then turned the heat down, and it was 60 deg or less in the morning when I went out there. I used the normal activator when I sprayed, because of the temp I was at, and had no problems. I am pretty sure that I could have sanded it after the 4 hours, if my wife hadn't had other plans.
I probably would have either used the fast activator, a mixture of the fast and normal, or raised the heat. Keeping the heat in the higher range for longer would probably have helped, as it always seems to cool off alot faster than it warms up. As for using a heat lamp, I personally don't think that is a good idea, as the metal is cooler than the surface of the paint. It would feel drier than it really is, because it is drier on the outside.
JMO
Aaron
  #48 (permalink)
Old 11-19-2005, 09:55 AM
Custom builder and painter
Last journal entry: Another test fit of the axle
well ill just add a little fast activator next time and keep it a little warmer throughout the night..
  #49 (permalink)
Old 11-19-2005, 03:52 PM
mrcleanr6's Avatar
the fact that you can mix the activators is great. i dont even buy the normal anymore. fast and slow and thats it. barry told me a 50/50 mix of the two would be within 10% of normal so its just one less thing i have to keep in the cabinet. doesn't matter if you use fast or not, it might help slightly but if it gets cold and stays cold overnight its going to go slow. my shop temps during the night goto about 60 like yours. in the summer i can sand and buff next day. during the winter months i wait atleast 3 days.
  #50 (permalink)
Old 11-19-2005, 04:22 PM
so your telling me that my only solution is to leave the heat at 70 degrees all night? the accelerator won't help in this situation..
i'm also assuming that it will buff better when cured more throurghly...
im just saying on some jobs I can't wait 3 days to buff.. for a few panels on a collision I have to be able to buff the second day, so i will need a solution or the universal clear will not cut it for me in the winter..
  #51 (permalink)
Old 11-19-2005, 04:32 PM
mrcleanr6's Avatar
well, you have to remember that any kind of curing pretty much stops at 55 degrees on any brand or type of clear so its going to depend on exactly how low the temp is. i have never used barry's accelerator so i cant say but if you keep the temp just a couple degrees higher, a hair over 60 then use the fast act. you should be ok. i'm sure the accelerator will help a little too if needed but the closer you get to that 55 mark the more you are really going to be extending the cureout.
  #52 (permalink)
Old 11-19-2005, 05:56 PM
well like i said the last time i turned it down to 60 after like 4hrs or so.. this time i'll use the fast hardener and leave it at 65 just to see how it goes.. and then adjust from there i guess...
wonder if barry has a suggestion for what combination to use
  #53 (permalink)
Old 11-19-2005, 06:07 PM
mrcleanr6's Avatar
65, fast hardener, you'll be fine.
  #54 (permalink)
Old 11-19-2005, 08:00 PM
ok thanks for your help.. as i'm new to this clear.. I think i like it but i just want to fine tune before i start ordering..
