Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - spi epoxy
Thread: spi epoxy
Old 09-14-2012, 03:44 PM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
I got the bodywork on the drivers side done today and put down a coat of epoxy. Just waiting for it to set then I'll put down three coats of 2-k on it. The 2-k that I've been using is Roblo from spain. If you use it as a super fill 4-1 with no reducer 3 coats are about the same as 2 coats of sprayable poly. It sands great after a overnight dry. You can reduce it to what ever thickness you want. 2 coats will fill 40 grit sanding marks. Hood and lid are ready to paint and Lt side is in primer and I've got right at 25 hrs. in it. While working on it today I found some spots on the glass where the sand from sand blasting etched the glass so all this damage was cause by some guy blasting it. THese things are thick to built like a tank. Its a shame because this was a pretty nice car from the looks of it. Only has 47,000 miles on it
ID:	67868   Click image for larger version
ID:	67869   Click image for larger version
