SPI Epoxy Q's - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2008, 04:15 PM
S10xGN's Avatar
Gotta love a turbo!
SPI Epoxy Q's
Hi All,
Well, the weather finally cooperated and I was able to my frame epoxied today. Somehow managed to get a few runs though. When is a good time to deal with these, while it's curing or after it sets? Tech sheet says recoat after 30 minutes, but it's still pretty tacky. Should I wait to overcoat?
Thanks!
Russ
Old 02-02-2008, 04:50 PM
Countilaw's Avatar
Cox Custom Cars
wait til it not tacky. Then recoat. You can recoat the next day if you want. Let cure for 12 hours and then you can sand out your runs.
Frank
Old 02-02-2008, 07:55 PM
The tech sheet is spec'd for spraying in 70's temperatures and you would be safe to recoat in 30 minutes if the primer is curing good. But if the temps are lower and if the frame was cool then the curing will be delayed and the recoat time extended. Epoxy requires good temps to cure properly.
Old 02-03-2008, 12:04 PM
S10xGN's Avatar
Gotta love a turbo!
Well, 18 hrs later it was set just fine. Runs all sanded out OK. Was able to get my 2 coats of Hammerite silver sprayed too. Frame is now finished and awaiting assembly after the Hammerite cures.
BTW, the Hammerite needs thinning to spray. Literature says almost anything can be used to thin, I used lacquer thinner about 3:1 and it sprayed great. Dry to touch in 30 minutes!
Thanks!
Russ
Old 02-03-2008, 12:44 PM
302 Z28's Avatar
Glad to hear it worked out OK for you.
Vince
Old 02-03-2008, 08:26 PM
S10xGN's Avatar
Gotta love a turbo!
Vince, are you driving your coupe yet? I haven't seen it or heard of any "sightings" yet...
Russ
Old 02-04-2008, 07:23 AM
302 Z28's Avatar
Russ
Yes, we had it out last Saturday at the Office Depot get together. Got almost 1000 miles on it so far.
Vince
Old 02-04-2008, 07:29 PM
S10xGN's Avatar
Gotta love a turbo!
I almost went, but I was busy up until 5:00 or so (then wore out afterwards).
From (white) SPI epoxy on Saturday, to (silver) Hammerite on Sunday, to fully assembled on Monday. Looks too nice to sell now! At least the frame turned out good, body is all rusted up and will require many days of work to "derust" again...
Russ
ID:	27647   Click image for larger version
ID:	27648   Click image for larger version
ID:	27649   Click image for larger version
ID:	27650   Click image for larger version
Quick SPI Epoxy Q... S10xGN Body - Exterior 23 01-04-2007 07:05 PM
SPI Epoxy Primer - Getting Started TBD Body - Exterior 12 11-24-2006 03:08 AM
Spraying SPI Epoxy - Orange Peel starquest Body - Exterior 11 11-04-2005 07:32 PM
SPI EPOXY PRIMER vs DP OR DPLF 36ford7 Body - Exterior 3 08-22-2005 09:34 PM
SPI Epoxy Question jdss Body - Exterior 3 10-17-2004 01:58 PM
