SPI Epoxy Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2012, 07:51 PM
SPI Epoxy Question
Hi everyone
I've been restoring a 72 Nova, took alot of the car down to bare metal and sprayed the 2 doors ,trunk and 1 fender with PPG shopline Epoxy primer before I found out about SPI.Does anybody know if I can spray the SPI epoxy over the shopline or would it be best to let them alone.
Thanks
Old 03-19-2012, 08:40 PM
Unless you have a need to cover it, you can just leave it alone. However, it is no big deal to sand the Omni and then apply SPI over it. I'm not sure what the window is for recoating Omni epoxy without sanding, but I would feel better sanding it regardless.
I'm no expert but I have sprayed SPI over other brands of sanded epoxy primer with no issues.
Old 03-20-2012, 05:49 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Epoxy is the most "compatible" coating out there.
It can be sprayed over almost anything as long as it's prepped properly
and clean. Sanding the existing surface first is always good insurance
for adhesion.
So yes, it can be sprayed over anybodys epoxy out there if
done properly.
another epoxy question. oldguy829 Body - Exterior 7 06-01-2008 09:35 AM
epoxy question crusherdbuzz Body - Exterior 1 10-23-2007 06:26 PM
epoxy question 71corvette Body - Exterior 4 07-08-2007 07:25 PM
SPI Epoxy Question jdss Body - Exterior 3 10-17-2004 02:58 PM
Question about epoxy over 2k misteryu Body - Exterior 4 08-31-2004 05:59 PM
