SPI Epoxy as Sealer - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2006, 11:08 AM
SPI Epoxy as Sealer
I am ready to paint the Nova. In fact, I used the reduced SPI epoxy as a sealer in the jambs, etc., then had to leave town for a couple of weeks. I had planned to do the jambing (seal, base, clear) then the rest of the car. What do I have to do to the sealer already laid down before I base it? I was going to just scuff it with a gray pad then go ahead with the base. Am I OK with that, or is there something else I should do? Thanks.
Old 09-06-2006, 12:47 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
I would sand it with some 400 and then base and clear.. the tech sheet tells you to scuff and re spray 1 coat of it if you have went past re coat window.. As I understand it, the base will bite into the epoxy and have better adhesion, vs. it being cured and like concrete.. either way it is little work..
If you choose to reseal, scuff it, spray one reduced even medium wet coat.. let flash for at a few hours ( tech sheet says minimum of 30 minutes for 1 coat, 1 hour flash for 2) then bc/cc
Old 09-06-2006, 02:50 PM
If the sealer went on smooth with no texture problems then just scuff it with a scotchbrite and apply another coat of sealer, let that set up overnight and apply your base and clear the next day for best results. If there's any texture problems in the old epoxy just sand them out like BK recomended or just sand it all-the main thing is get the surface scuffed up some for the new coat of epoxy to adhere to.
You can paint over the old epoxy but adhesion wouldn't be as good as painting over fresh epoxy.
You can paint over epoxy after a minimum 1/2 hour wait but the as sprayed gloss ends up being better if you let the epoxy set overnight or longer (within the recoat window). Hope this makes sense, Bob
Spraying SPI Epoxy - Orange Peel starquest Body - Exterior 11 11-04-2005 07:32 PM
Is epoxy sealer suppose to be shiny? FrankR Body - Exterior 1 09-25-2005 09:03 AM
SPI EPOXY PRIMER vs DP OR DPLF 36ford7 Body - Exterior 3 08-22-2005 09:34 PM
What grit? before and after epoxy sealer ? 67LS1T56 Body - Exterior 7 08-17-2005 10:04 PM
SPI Epoxy Question jdss Body - Exterior 3 10-17-2004 01:58 PM
