SPI Epoxy as Sealer - Barry K?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2006, 10:53 AM
I am going to seal the Nova with SPI Epoxy reduced 20%. Question is - how much time do I have before I MUST Base it? There might be issues of weather, temp, etc. to deal with after sealing. Thanks.
Old 10-02-2006, 03:53 PM
Seven days unsanded.
If it stays in the garage after 7 days you can use a gray scuff pad before base.
If car is outside or driven you must scuff and re coat with epoxy.
Old 10-02-2006, 05:35 PM
colormecrazy's Avatar
Paintshop Dog
I'd suggest that if you have to leave it over an hour. You gently run over it with 1000 grit (with a little water)and knock off the lumps, trash, and texture. Then base it. Why not take advantage of a dry substrate when you can. Just an idea. The smoother the under-coat the smoother the top-coat.
Old 10-02-2006, 07:37 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
There is no reason for him to touch it unless he has some trash he has to remove or If it were going to be a top end show car finish, then yes, I would say wet sand it with 600 the next day and base.. Is that the case here??
Old 10-03-2006, 04:28 AM
adtkart@aol.com
If eveything is right, the epoxy should spray and appear like a base coat. If that is the case, barring any imperfections, like trash, orange peel, or runs, like Bondoking said, there is no reason to sand it, unless you are over the 7 days.
Aaron
Old 10-03-2006, 08:13 AM
How about how soon can you spray over it? I like the idea of epoxy as a sealer but sometimes the overnight wait can be a problem so how soon can it be safely top coated?
Old 10-03-2006, 08:28 AM
adtkart@aol.com
According to the Tech sheet,
Spraying:
Spray one wet coat for normal applications. For special projects such as restorations
Spray one coat and let it flash about 10 minutes at 70° degrees or higher. Then spray second coat for maximum corrosion protection. If one coat of epoxy is used wait 30 minutes before painting. With two coats of epoxy wait 60 minutes to paint.
Aaron
Old 10-03-2006, 09:32 AM
Some where I got the idea that waiting overnight was required, wish I had of asked sooner, Thanks
Old 10-03-2006, 10:10 AM
Thanks to all. The weather turned to crap today, and I'm leaving town for a while (going to Ireland for ten days). So everything will have to wait until I get back. I just don't want to spray anything with cold, rain and high humidity out there to spoil it all.
Old 10-03-2006, 10:29 AM
adtkart@aol.com
You may have gotten that from "The Perfect Paintjob". In there, everything was to the extreme. I was doing that at first.
Aaron
Old 10-03-2006, 03:45 PM
Most epoxies used as a sealer (additional reduction) will have recommendations of 30 minutes to four hours for applying base.
Of course overnight is always best and as pointed out overkill.
SPI Epoxy as Sealer nova69 Body - Exterior 2 09-06-2006 02:50 PM
Is epoxy sealer suppose to be shiny? FrankR Body - Exterior 1 09-25-2005 09:03 AM
What grit? before and after epoxy sealer ? 67LS1T56 Body - Exterior 7 08-17-2005 10:04 PM
Spi Epoxy Question, Barry K 67goat Body - Exterior 7 07-21-2005 08:55 AM
Barry, epoxy adhesion testing? baddbob Body - Exterior 21 03-20-2005 09:12 PM
