Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - spi epoxy test
Thread: spi epoxy test
Old 06-11-2013, 10:24 AM
shine's Avatar
shine shine is online now
SPI Thug
Last journal entry: some progress
spi epoxy test
i think this will be about the 5th time this has been done on this board over the years . when the bs gets deep someone does it.
this test panel was sanded with 80 grit and cleaned with solvent base cleaner.
shot 2 med wet coats with a 1.4 at noon yesterday .
80 degrees in my booth
after approx 18 hours of cure
scrubbed with lacquer thinner until rag dried
only some slight residue came off . look close and you'll see my finger prints so i was not being gentle .
now this should put this to rest for a few years again .
this test was done to help those who do not post but need correct info on products or are looking for help. please do not move it to the paint only sub forum . i do not use cheap 3rd line paints so i can offer no help there . that seems to be the main reason for the sub forum.
signed " one of the spi thugs "
Name:	epoxy test 1 (2).jpg
ID:	74801   Click image for larger version
Name:	epoxy test 2.jpg
ID:	74802   Click image for larger version
Name:	epoxy test 3.jpg
ID:	74803   Click image for larger version
Name:	epoxy test 4.jpg
The Following User Says Thank You to shine For This Useful Post:
cyclopsblown34 (06-22-2013)
