Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - spi epoxy test
Thread: spi epoxy test
  #96 (permalink)
Old 06-13-2013, 08:38 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
On another note, if reducers didn't enter a substrate to form chemical bond, why would some be harsher than others, why would there be a need for some reducers that if not used properly that can actually wrinkle an existing finish...if all that was left was mechanical adhesion...that's one problem that most of us have experienced. Reducers, acetone, varsol, gasoline are all solvents, Lacquer paint is cut with Lacquer thinner...what does lacquer thinner do to lacquer paint, it will take it off if to much is used, if the right amount is used it will penetrate the lacquer paint and again, give a chemical bond.
Ray
