spi epoxy test - Page 10 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #136 (permalink)
Old 06-16-2013, 05:24 PM
302 Z28's Avatar
I probably had a few post in that "epoxy primer wipes off with a lacquer thinner soaked rag" thread from a while back. I actually did the test myself with my steel 34 Ford 4 piece hood which had been primed with PPG DPLF and set in my garage for over six months until I read that very thread. I went to the garage and with a lacquer thinner soaked rag wiped the DPLF right off like it was still wet.. Cleaned it all off and purchased SPI and never looked back.
Vince
Quick reply to this message
The Following User Says Thank You to 302 Z28 For This Useful Post:
DLT (06-16-2013)
  #137 (permalink)
Old 06-17-2013, 12:05 PM
Pats55's Avatar
In a previous post I asked a question about sandability and if a epoxy formulation with good sandability would lose something on the other end, like solvent resistance or adhesion. My lab guy Steve says you don't necessarily have to lose anything. A lot of times in paint formulations when you change something you lose something .From what I gather in this instance if it did lose something it would be very minimal.
  #138 (permalink)
Old 06-17-2013, 12:10 PM
life is a temporary assignment
Vince
Now Vince... You do know what this now means...hehehehehe
  #139 (permalink)
Old 06-17-2013, 02:02 PM
Pats55's Avatar
I'm curious, what does it mean?
  #140 (permalink)
Old 06-17-2013, 02:37 PM
Now come on Mr.Pat... You have been here long enough to know what I was getting at...
This means Vince is now part of the club.. I think vince already knew this..
  #141 (permalink)
Old 06-17-2013, 03:22 PM
Pats55's Avatar
Oh I thought it meant that when I have a question I go to the experts and get the answers. Oh silly me. Well one thing after speaking to the lab people I learned a few things,I am not really a epoxy guy. I mostly deal with moisture cure , and two component urethanes. As you probably know I am resurrecting the old zinc rich primer which will be in epoxy. The Mastercoat Zinc Rich Primer will be a little softer giving it good sanding properties, great adhesion, and some flexibility.You all can relax it's not for you guys ,this'll be for the companies industrial accounts.Again thanks, I'm always learning something new.
  #142 (permalink)
Old 06-17-2013, 03:44 PM
Irelands child's Avatar
Now - that's a wee bit condescending!!
Irelands child
  #143 (permalink)
Old 06-17-2013, 03:59 PM
Pats55's Avatar
My apologies didn't make it sound like that. Sometimes when you try to be cute to get into trouble. Again my apologies
  #144 (permalink)
Old 06-21-2013, 12:16 PM
Ok, so I just ordered my first SPI epoxy primer. One thing I noticed in the tech sheet was the 30 minute induction period.
We strongly recommend you activate the epoxy by first stirring very well and then
allowing it to set/ induce for 30 minutes. Stir once again before spraying and the longer
you wait between spraying your coats of epoxy the better.
These two things tell me that it isn't going to totally insoluable for many days, or maybe never if this isn't done properly. I would think, maybe this is the big difference in one test to another.
  #145 (permalink)
Old 06-21-2013, 12:40 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Brian,
I have sprayed it both ways and haven't noticed a difference, but maybe it gives it more time to cross-link?
  #146 (permalink)
Old 06-21-2013, 12:44 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
brian , if you are going to try to build with it let it set overnite in a covered pail . it will build better then . if not the 30 min induction is all you need . especially if you reduce it with urethane reducer .
The Following User Says Thank You to shine For This Useful Post:
MARTINSR (06-21-2013)
  #147 (permalink)
Old 06-21-2013, 12:48 PM
Pats55's Avatar
The biggest mistake people make with epoxies and urethanes they don't read the product data sheet. Most epoxies have an induction time anywhere from 30 min. to one hour. With our AG 111 they don't stir the a part A of first ,or the hardner is not stirred in thoughly causiing soft spots in the coating or the coating just generally fails It's always a smart idea to get the product datasheet before you start playing with paint. Thank God today you can usually just get on the computer and get a sheet.As for cure times there are so many variables. Hope this helps.
  #148 (permalink)
Old 06-21-2013, 01:00 PM
The nice thing is the 24-48 hr pot life. If I have extra left over I cover the mixing cup with foil and store it in the house, and can spray spots I missed or something new that I prepped the next day, or even two days later. Generally I will prep all kinds of little spots to touch up all over the car and will end up forgetting some of them, which is really aggravating.
  #149 (permalink)
Old 06-21-2013, 01:09 PM
According to the tech sheet it's 72-120 hours!!
Thanks for the tip Shine.
  #150 (permalink)
Old 06-21-2013, 01:10 PM
There is nothing I have repeated more over the years on the forums than....
"FOLLOW THE MANUFACTURERS TECH SHEET!"
Closed Thread
spi epoxy swvalcon Body - Exterior 14 09-24-2012 06:34 AM
spi epoxy shine Body - Exterior 18 07-11-2011 05:25 AM
Flash rust OK under epoxy? SPI epoxy primer, Transtar 6131, or PPG Shop Line? off2wildblue Body - Exterior 2 07-29-2010 08:53 PM
SPI epoxy imperialman67 Body - Exterior 9 09-05-2009 06:34 AM
SPI Epoxy Q's S10xGN Body - Exterior 7 02-04-2008 07:29 PM
