spi epoxy test - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 06-11-2013, 10:24 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
spi epoxy test
i think this will be about the 5th time this has been done on this board over the years . when the bs gets deep someone does it.
this test panel was sanded with 80 grit and cleaned with solvent base cleaner.
shot 2 med wet coats with a 1.4 at noon yesterday .
80 degrees in my booth
after approx 18 hours of cure
scrubbed with lacquer thinner until rag dried
only some slight residue came off . look close and you'll see my finger prints so i was not being gentle .
now this should put this to rest for a few years again .
this test was done to help those who do not post but need correct info on products or are looking for help. please do not move it to the paint only sub forum . i do not use cheap 3rd line paints so i can offer no help there . that seems to be the main reason for the sub forum.
signed " one of the spi thugs "
Name:	epoxy test 1 (2).jpg
ID:	74801   Click image for larger version
Name:	epoxy test 2.jpg
ID:	74802   Click image for larger version
Name:	epoxy test 3.jpg
ID:	74803   Click image for larger version
Name:	epoxy test 4.jpg
Quick reply to this message
The Following User Says Thank You to shine For This Useful Post:
cyclopsblown34 (06-22-2013)
Old 06-11-2013, 11:08 AM
Thank you very much, what part number is the epoxy? I have never gotten any but plan on it and I see the three different colors and what not, so I want to be sure what I am getting.
Old 06-11-2013, 11:15 AM
shine's Avatar
SPI Thug
6620-4 is the black . there are only 3 . white/black/gray , qrts or gals.
Old 06-11-2013, 11:17 AM
Faith - Respect - Trust
Apparently I missed the whole thread...and now I see a "paint" sub forum...(don't know why there needs to be a paint sub forum...but anyway).
Did I miss something that maybe I should know about? I've read between the lines and apparently a thread got tossed and all I've heard is that it may have something to do with...or the thread was SPI "cult" suggestive.
If somebody can fill me in...even a PM would be appreciated if this is that delicate a topic. The reason I ask is that I've become a fan of SPI products and any information regarding this product...I'm interested in.
Ray
Old 06-11-2013, 11:20 AM
shine's Avatar
SPI Thug
look in the dump . one of the stupidest threads i have seen here in the 10 years i've been here.
the sub forum ranks right up there with it . useless and just confuses people. i hate to inform them but it is body and paint. always has been .
Old 06-11-2013, 11:27 AM
Thanks, right on, will be getting mine soon.
Old 06-11-2013, 11:35 AM
Don't know how to check the dump but will try to figure it out. I agree with the paint and body staying paint and body...why, that's what it is, paint and body...it's not metal work, filler work, primer work, prep work and paint work. They are so dependent on each other they need to be in the same category or, as you mentioned, it'll just confuse everybody.
Ray
The Following 3 Users Say Thank You to 69 widetrack For This Useful Post:
dinger (06-12-2013), NEW INTERIORS (06-11-2013), OneMoreTime (06-12-2013)
Old 06-11-2013, 11:41 AM
life is a temporary assignment
Ray
Here you go Mr.Ray..http://www.hotrodders.com/forum/spi-...ml#post1682343
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
69 widetrack (06-11-2013)
Old 06-11-2013, 11:55 AM
Hey Shine !!! Send me ALL that extra SPI primer you have, instead of wasteing it on these test.. We know it work's already...
MARTINSR (06-11-2013)
Old 06-11-2013, 12:08 PM
REALLY! I can use some too, white and black please.
Old 06-11-2013, 12:15 PM
Thanks for the link Randy...I read all of the posts several times and have come to one conclusion...some peoples computers must say "Fischer Price" on them instead of Dell, Apple or HP...LOL
Ray
Old 06-11-2013, 01:48 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I use SPI epoxy exclusively, so don't get me wrong, but
I don't think weather lacquer thinner can disolve the surface
proves anything.
Wouldn't it hold the paint better if the top coat DID dissolve
into it a little?
If it's so hard that there can be no chemical bond, then only
the scratches hold the paint on? Is that better?
I just don't understand what all the fuss is over, it's
a moot point to me. I know it's good primer, I don't care
if it wipes off or not, it's covered with paint.
Old 06-11-2013, 11:49 PM
put up or shut up
I'm sure it would absorb a base when applied wet on wet. more or less just showing you how strong the barrier is against water vapers/lock out. Impressive. I really wish Shine would have sprayed another brand or two at the same time to show comparisons. I'll be ordering a gallon for my Stang for final block when my lazy butt gets around to it.
Old 06-12-2013, 12:48 AM
dinger's Avatar
I don't see much reason for the paint sub forum myself. As to the poster that originated the SPI thug term, he was called out, and didn't bother to substantiate his claims. As far as Barrys' products go, I don't recall one complaint about his stuff. Can't say that about most products. Barry has been an asset to this forum and he does have his fans. I don't know of any other owners of paint companies that you can call on the phone for help.
As far as the sub forum goes, if it turns out to be just a bunch of opinions about paint, it really has no technical merit and will probably die a slow quiet death.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
The Following User Says Thank You to dinger For This Useful Post:
NEW INTERIORS (06-12-2013)
Old 06-12-2013, 05:46 AM
Pats55's Avatar
You do now. Here at Master coat, we answer the phones from 8 AM to 10 PM. I may no longer be the owner, but when the phone rings and they're not quick to pick it up, there will be hell to pay.The phone rang Christmas morning ,turned out to be a lady looking for free telephone. This is the only post I will make in regard to this topic. If you have a technical question I'll be most happy to answer it to the best of my ability
Closed Thread
spi epoxy swvalcon Body - Exterior 14 09-24-2012 06:34 AM
spi epoxy shine Body - Exterior 18 07-11-2011 05:25 AM
Flash rust OK under epoxy? SPI epoxy primer, Transtar 6131, or PPG Shop Line? off2wildblue Body - Exterior 2 07-29-2010 08:53 PM
SPI epoxy imperialman67 Body - Exterior 9 09-05-2009 06:34 AM
SPI Epoxy Q's S10xGN Body - Exterior 7 02-04-2008 07:29 PM
