Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spi Sealer/deltron Basecoat/spi Clearcoat?
Old 02-17-2012, 06:47 AM
bigriver bigriver is offline
Keep in mind I'm a DIYer at this and I have read enough to no there are alot variables that can come in to play. It has been 7 or 8 months since the paint job so I'm a little rusty on details of the actual paint mixes.
Chips to the epoxy. Best I can tell the epoxy primer/sealer is fine. Just something happened between the BC/sealer. And the clear does not have that pop. I used a pint of PPG clear on the fender flares and they look assume. Only thing I can think of is that I sprayed the sealer to thick around the fender wheels and the sealer did not flash off good. I wet sanded and buffed this truck pretty good it never pulled any paint lose or anything.
Yep the clear was 3:1. In came with the correct ratio.
When I sprayed the epoxy primer as sealer I reduced it about 30%. Tech sheet says 10%-50%. Basically I choose somewhere in between.
