Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SPI Universal clear....WOW
Old 06-07-2011, 10:01 AM
67Elcamino's Avatar
67Elcamino 67Elcamino is offline
Im shooting SPI Universal clear out of a Finishline III with a 1.3 tip and its splaterring the clear. Ive played with the adjustments on the gun and no luck. I also switched to another cheap gun with a 1.4 tip and same results.
What are you guys shooting the SPI clear with? Are you guys reducing it? The tech sheet recommends that you use 1.4 tip but by seeing how thick this stuff is seems like it either needs to be reduced or a bigger tip. any suggestions?
Even with the splattering Im able to cut and buff to get rid of the orange peel but in some corners I just cant get to it.
Does anyone out there know how this clear will stand up leaving the car outdoors for a extended period of time?
