-   -   SPI Universal clear....WOW (http://www.hotrodders.com/forum/spi-universal-clear-wow-199832.html)
mr4speed 06-04-2011 09:36 PM
First time spraying the SPI clear on a 54 Eldorado and I must say its everything I have heard it was if not more. I have always used concept 2021 clear and this stuff is not even comparible. Very IMPRESSED!!!
panelwagon62 06-05-2011 12:16 AM
Welcome to the club.
NEW INTERIORS 06-05-2011 01:28 AM
More Great new for SPI !!!! Glade to have you with us.... :thumbup: :thumbup:
mitmaks 06-05-2011 02:35 PM
what did you like about it?
Sixguns 06-05-2011 03:00 PM
are you going to cut and buff, be ready to be impressed all over again.
mr4speed 06-05-2011 03:00 PM
Lets see, first off the car is a cream white so not really a color your gonna notice a lot of depth in, but I must say this, 2 weeks ago sprayed a black 55 chevy with the 2021 and even on a black car the depth of the clear on that versus the depth on the white is definetly deeper on the white. Both cars are side by side, both cars were done with concept single stage and cleared 2 hours later and everyone who sees it can see a difference. Flowout definately better as well, and dont get me wrong have used PPG 2021 on most of the cars I do and have been happy with it. Just figured I would give the SPI a shot to see how it was after hearing all the positive feedback about it. And I think this is the clear I will be using from now on.
jeremyb 06-05-2011 03:35 PM
obviously this is just bandwagon snake oil stuff!! :rolleyes:
Glad you finally tried it and are impressed. The DOI of the spi clear is just amazing. When you cut and buff, you will love it even more. Of course, i'm just on the bandwagon..i surely dont know what i'm talkin about as I only use this stuff everyday on multiple high-dollar restos..... :rolleyes:
:D
post up some pics!!
67Elcamino 06-07-2011 11:01 AM
Im shooting SPI Universal clear out of a Finishline III with a 1.3 tip and its splaterring the clear. Ive played with the adjustments on the gun and no luck. I also switched to another cheap gun with a 1.4 tip and same results.
What are you guys shooting the SPI clear with? Are you guys reducing it? The tech sheet recommends that you use 1.4 tip but by seeing how thick this stuff is seems like it either needs to be reduced or a bigger tip. any suggestions?
Even with the splattering Im able to cut and buff to get rid of the orange peel but in some corners I just cant get to it.
Does anyone out there know how this clear will stand up leaving the car outdoors for a extended period of time?
67Elcamino 06-07-2011 11:03 AM
:D
post up some pics!!
What system are you suing to cut and buff SPI clear?
jeremyb 06-07-2011 12:32 PM
i use an iwata w400lv 1.4 for spraying. Unreduced. Just mix 1-1 with activator.
Depending on the job at hand, i start cutting with 800 or 1000. Work my way up to 3000 trizact and use mequiars diamond cut compound and a wool pad.
I let the car sit in the sun a full day before cutting, then let it sit another full day after the initial 800-1000 cut.
this is after just the wool pad.
http://i23.photobucket.com/albums/b3...e/P1080057.jpg
http://i23.photobucket.com/albums/b3...e/P1080052.jpg
Hotbo 06-07-2011 01:32 PM
i use a Devilbiss Millenium GTI with a 1.4 and it lays the UV clear 1-1 out almost like glass.
are you moving to fast??
the UV clear is the easiest clear i have ever sprayed,very little learning curve and i have shot many different types and Brands of clear.
Travis...
chas350 06-07-2011 07:26 PM
sounds like your gun may need a good cleaning?
67Elcamino 06-07-2011 11:39 PM
Im not an expert and do not have much experience shooting clears. Im just wondering if I need more PSI. I noticed that when I use the PSI setting recommended by the gun it barely shoots paint. When I increase the psi a bit seems to work fine. Will this PSI effect the finish and create orange peel in the clear. I noticed by watching some videos of people shooting clear its shoots very misty. Maybe Im laying too thick.. Im going to test and adjust my gun before starting next time. I just purchases a gun with 1.4 tip
mitmaks 06-08-2011 12:22 AM
You adjust gun to work for YOU not the other way around
jcclark 06-08-2011 06:32 AM
Most HVLP's work better with a little higher PSI.
I'm starting to think the mfg recommended pressure is more for
enviromental reasons than spray quality. :rolleyes:
