Spider Problem under carriage and under hood of car! Help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2010, 03:45 AM
LittlemissV8's Avatar
Ambition is a dream with a V8
Okay, so I noticed I've had webs under the hood and webs on around the bottom outside of the car, I just bought this car about 2 weeks ago and it sat in the previous owners back yard for about 5 years, enough time to infest the car with spiders, They are black widow spiders (and are poisonous) I didn't find it to be a problem until today when I was checking the oil a huge black widow came crawling up my arm its friggin' annoying, I have cleaned the inside continuously and tried spraying the undercarriage with a waterhose, every time I see a web I try and get rid of them, but the next morning there they are again! I've killed over 7 black widows and I know there are more! Has anyone else had this problem?
Any idea how to destory all of these you-know-whats?
Old 07-13-2010, 06:02 AM
I have but it was those damn stink bugs! Everywhere on the interior even under the dash!! I would suck em up with the shop vac everyday.
Check in to getting a few of the bombs like you use on fleas and bomb the hell out of the garage!!!
Old 07-13-2010, 06:23 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I think what I would do is to get a large roll of plastic sheeting..enough to cover the whole car as in a tent and then set off some of those bug bombs under the tent..you can get the bug bombs at the hardware store..
Sam
Old 07-13-2010, 06:39 AM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Spiders are soooooo gross. My least favorite creature. I would suggest luring them all out with a treat and then attacking them with carb cleaner and a lighter.
In all seriousness, I'd suggest using a bug bomb and then finishing up with a can of raid. Or if you're really scared of spiders you can just get a friend to finish up with a can of raid. That's what I'd do.
Old 07-13-2010, 11:00 AM
dinger's Avatar
You can do a lot of things that won't work. To kill the black widow, you have to hit them with a spray, they are not bothered by residual. To make them leave, treat the car with something oily that they won't like, maybe some orange oil based cleaner. Spray the underside of the car and the hood. Black widows like dark moist places to hide, they are hard to be rid of. I know they don't like diesel but that would make quite a mess.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 07-13-2010, 03:11 PM
hahaha, you read my mind with your first suggestion!
just kidding, I think I am going to go for the bug bomb effect and try and finish of the little buggers with raid if I have too...
Old 07-13-2010, 03:16 PM
Ooo I had no idea, maybe bombing the car wont do anything, I don't want to do all that work of covering the car and bombing the car and it not work...I'll look into finding some orange oil based cleaner first.
Old 07-13-2010, 03:20 PM
ew, those creatures sure are no fun! Thanks for the help ! I hope that those stink bugs stayed away...Any bugs in any car gets annoying!
Old 07-14-2010, 07:02 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
My car had so many black widow spiders that I was thinking of calling it that.
I toasted them with a propane torch.
Old 07-14-2010, 07:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you tent the vehicle and set off multiple bombs- you have in essence MADE a bomb! The propellants of a lot of those bug bombs is (was) flammable, so be damned careful w/kids fooling around, water heaters, shorts making a spark, etc. when you remove the covering.
In a high enough concentration (like while sealed up under the sheeting) the a/f ratio may (or may not) be too rich to explode. But add some O2, and look out!
Old 07-14-2010, 08:06 PM
Used to use the bombs in my homes in Fla about every 6 months. We would place one in each room and set them off while getting out as quickly as possible. We would come back about 8 hours later and air out the mess. NEVER thought about this being an explosive mixture. We never killed the power, thus hot water heater, air handling system and other normal electrical items were switching on and off as normal. Did we dodge a big one?
Trees
Old 07-14-2010, 08:19 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Trees
I doubt the size of the enclosure you were dealing with would allow for a combustible mixture to have been created, as long as you followed the directions or at least didn't triple the recommended amount or something like that.
But that said, there HAVE been reports of homes being quite literally blown to hell and back by the improper use of these bombs.
In the case of a tented car w/several bombs, the concentration could produce an explosive mixture under the right (wrong?) conditions, and that would be my concern.
Old 07-14-2010, 08:53 PM
Definitely don't want that, I killed 4 more today, I still haven't made up my mind on a sure way to get rid of 'em, they are pretty much spread out all under the car and hiding in every dark place of under the hood... Guess I'll just have to be careful where I stick my hands while working, or wear gloves and long sleeves to prevent getting bit.
Old 07-14-2010, 09:07 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I have been bit by a black widow . Aching chills all over ,every joint hurt , cold sweat . Shivering cold . Could not get warm no matter how many blankets. Was bit in my sleep. Found the bite mark next morning. Didn't know what was going on 'till then
Old 07-14-2010, 09:22 PM
Oh man, that's not good at all, good to know you are fine now though! Here's to hoping I don't get bit anytime soon! lol
