spider retainer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2003, 10:57 PM
New Member
spider retainer?
Hi there. I have a 350 (unknown year), and I would like to put a different camshaft in. I found the cam I want (MTC-1), it's a NonRoller Hydraulic.
someone told me to find out if my engine needs a roller cam, there will be a "spider retainer" visible when the intake is taken off.
What does this spider retainer look like? Or, is there another way to tell if I need a roller/nonroller cam? (easiest/quickest way, if possible).
Thanks so much!
Old 10-17-2003, 11:06 PM
Jmark's Avatar
Ahh, another poster in PHx.. Welcome!
Never heard of a "spyder retainer" before. What I'm assuming he's talking about is a thrust button on the front of the camshaft. If it has one, it will be visible when the timing cover is off. Never seen one inside the valley area.
They are used on roller cams only. They keep the cam from moving forward and backward in the block. The button is mounted on the end of the cam and is held in by a metal plate that has tangs that are bent onto the 3 cam gear bolts to keep them tight.
Non roller cams have the lobes ground on a very slight angle to aid in lifter rotation and it also keeps the cam in the block.
Roller cam lobes are ground ( for a lack of a better word) flat, so cam walk can be a problem.
Old 10-17-2003, 11:24 PM
DoubleVision's Avatar
the spider retainer is used in factory roller cam blocks, it`s job is to hold the roller lifter retainer in place so they don`t rotate in the bores. factory roller blocks were used from 1987 on and mostly in passenger cars. the spider retainer uses 3 bosses in the intake valley to bolt on to. these blocks have there own camshaft retainer that bolts on to the block behind the timing chain so the cam can`t walk.
Old 10-17-2003, 11:33 PM
Jmark's Avatar
Well, thanks for clearing that up! LOL I"ve never had a factory roller sb apart yet. Building older rollers now.
Old 10-17-2003, 11:39 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Re: spider retainer?
Well that narrows it down to about thirty years, post some numbers from the block and we can probably tell you what you need without tearing into it.
Old 10-18-2003, 12:30 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
I use the cam button on all performance engines.
Troy
Old 10-18-2003, 07:33 AM
NorthStar's Avatar
spiders have 8 legs and so does a spider retainer
Old 10-19-2003, 12:25 AM
New Member
hey, thanks guys! I'll take off my timeing cover and have a look!
The cam I'm looking to purchase comes with lifters in the kit, so would it even matter if my engine currently has a rollercam/lifters? (the new cam isn't roller). I'm not looking to get ball splitting power, the cam in question (Melling MTC-1) is a low end cam (probably for 350 truck engines) and is supposed to be very good on gas milage.
I'm not worried about a lack of high end, I don't race much, I'm just looking for a nice sounding idle (a little bit of chop) with better gas milage. I'm told that this cam will give me what I'm looking for.
Sorry, I'm a bit new to cams
Where will the block numbers be? is it the only thing writen on the block?
Old 10-19-2003, 01:52 AM
http://www.gmgoodwrench.com/gmgoodwr...347&section=ep
Look at the roller tappet guide retainer. That's the spider. It lives under the intake manifold.
Old 10-19-2003, 03:22 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
You can look on the back of the block behind the driver side head, on the block will be a number like 3970010 etc. Or if you can see it, there's the numbers on the front of the block just in front of the passenger side head. The numbers on the back of the block will be easiest to decipher for me anyway.
