spindle hitting lower a arm when turning - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2010, 01:54 AM
I just put a Jegs disk brake up grade on my 57 chevy belair. 2" drop spindle and 11" cross drilled and slotted rotors. The spindles are much thicker then the stock ones and hit the lower a arm when turned both ways. I don't have much steering at all now. Any ideas?
Old 05-19-2010, 11:22 PM
327NUT's Avatar
Did you run it by Jegs to see what they have to recommend?
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
Another Mustang II Question hiimed Suspension - Brakes - Steering 7 06-30-2003 09:48 AM
Spindle help DoubleVision Suspension - Brakes - Steering 5 06-25-2003 01:18 AM
poly lower control arm bushings dusterbd Suspension - Brakes - Steering 2 11-13-2002 03:19 PM
Lower control arm bushings. What are the tricks of the trade?? Jim Weeks Suspension - Brakes - Steering 7 05-11-2002 08:08 PM
