Spindle ID help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2004, 06:35 PM
KA67_72's Avatar
Spindle ID help
I need help identifying the spindles on my truck. Click on my avatar and take a look at the spindle pic. I also need to know where I can find hubs and bearings for it. I got axle and wishbone with a 26-27T coupe and a Model A frame. If you need measurements just let me know.
Thanks,
Kevin
Old 08-10-2004, 03:19 AM
Frisco's Avatar
Glad To Be Here
Because of the kingpin that is in the photo; I'd say the spindle is a stock Model 'A' 1928-1931. There are adapter kits available to put 1940-1948 Ford, Mercury or Lincoln hydraulic brakes on those spindles. Switch to 1937-1948 Ford as there are many brake kits that will fit the later spindles and the kingpin diameter is the same as the model 'A' if you intend to use that axle.
