spindle question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2007, 07:22 AM
spindle question
Can one convert a 4 wheel drum 6 lug 2wd 67-70 chevy truck to 5 lug disc by using 73-87 spindles ?
Thanks
Shane
Old 04-12-2007, 08:49 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
It's been a long time since I did one;and mine were all 63-66 c-10s
I believe the balljoint & tierod tapered holes were the wrong size. Might be just one balljoint, upper or lower, and I seem to recall swapping the a-arm on lower or upper. Sorry I don't have good info, but that swap has been done by many....maybe someone will post the correct info.
I also recall some sort of tierod adapter setup to go from small taper to big. But I found a center link from a 66 c-20 that had big tapers to bolt it all together without store bought stuff.
Best way is use 71-72 c-10 discs and get the proportioning valve too.
I don't know if you swapped the rear bolt pattern yet? The 69 & older c-10 has "short" axle shafts and you can't put in the 71 & up 5 lug shafts. The 70 had long axles so you can swap in the 71-up 5 lug shafts.
Old 04-13-2007, 01:18 PM
I was just curious if I should happen to get a 4 wheel drum truck of this vintage thanks for your help
Shane
Old 04-14-2007, 09:34 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Upper and lower control arms,
Spindle
Master cylinder and booster
From what i have been told it is a bolt in from 1963 to 70
You can get more info on this at the 67-72chevytruck.com
I plan on doing this to my 64 c-10 short wide (for my son)
You will then have the rear axle to deal with
Bryan
Old 04-16-2007, 11:56 PM
www.67-72chevytrucks.com/vboard
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Mustang 2 spindle question al37ford Suspension - Brakes - Steering 4 04-02-2007 06:14 PM
37-48 Ford Spindle bolt pattern? farna Suspension - Brakes - Steering 1 06-02-2006 11:18 AM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
