Spindle question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2006, 04:08 PM
Spindle question.
is the 37-48 ford spindles the same as model A spindles ('29) ? because I want to order steering arms for ford '37-'48 and I want to make sure it fits first.
and does the ford f-100 '48 spindle fit on the I beam are the king pin the same size?
Old 10-03-2006, 08:56 PM
BOBCRMAN@aol.com's Avatar
37-48 spindles ARE NOT THE SAME as earlier spindles such as Model "A" or 32's -36. Earlier spindles have less vertical height. (about 1/4") will not fit later axles unless the king pin boss on the axle is shortened. Also the backing plate holes on earlier spindles are smaller as is the centering ring for the backing plates. King pins are also about 1/4" shorter than 37-48. Same OD. King pins on 36 and earlier have a big ugly bulb shaped bracket as part of the unit. I have sawed it off and inserted a soft plug in the hole. Also, 36 and earlier King pins are hollow!!
As for the small truck spindles. I have no experience with them, but, have read that they are the same.
Old 10-04-2006, 05:53 PM
I want to buy steering arms that bolts on the holes of the round back plate... I was wondering if they will fit if I drill the holes bigger,(if they are to small) are the holes the same distance apart? (the bolt pattern)
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
