which spindle and rotor to use on 1931 graham axle so 5 lug GM wheel fits - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2010, 09:37 PM
I Have A 1931 Graham With The Original Axle And Would Like To Put On Some Gm 5 Lug Wheels.it Has 12 In. Brakes Up Front That I Would Like To Use . Is There A Spindle And Correct Brake Rotor Off Another Year And Make That Would Work For My Application. Or Do I Have To Find Another Axle Assembly That Has That Gm Bolt Pattern . Please Help Me !!!!! Fred
Old 08-01-2010, 10:48 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
How I would approach this:
First compare the length of the Graham spindle to the chev spindle to see that the length of the Graham spindle will allow you to get the washer and nut on and get a cotter key in..if that works then measure the OD of the bearings to fit the chev rotor and the ID of the bearing to fit the Graham spindle..Once you have that then go to a bearing catalog and try to find some bearings of the correct OD and ID for your application..
Just may work..Good Luck
Sam
Old 08-02-2010, 05:42 AM
BOBCRMAN@aol.com's Avatar
Or if that doesen't work. The spindles can be machined. Call All-Tech Performance, Burton. In the book.. Ask for big Bob
Old 08-02-2010, 10:42 AM
What Chevy Spindle And Rotor Do I Use To See If This Is Going To Work. Can You Still Find These At A Scrap Yard Or Do I Have To Go To A Swap Meet. Thanks For Info , Fred
Old 08-02-2010, 11:01 AM
Wiki Edits: 3
Those can be found at the pick-a-part..just pick one and try it till you find something close enough...
Sam
Old 08-02-2010, 11:41 AM
Wiki Edits: 3
Another point is that I would pick a metric rotor and caliper such as used by Speedway Motors on their MII conversions as those work wellfor this sort of thing..
Sam
Old 08-02-2010, 05:25 PM
Problem with most thirties cars is the spindle stub is too long. Has to be cut/rethreaded/cotter hole redrilled..
When I change these I usually use the spindle dimensions of Ford Mustang, Ranger or Granada. Then adapt bearings/seals to fit..
