Spindle thread repair on my '57 Chevy Pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2013, 04:19 PM
roger1's Avatar
I'm restoring my '57 pickup and just today I dissembled the front brakes and removed the drum and hub. My spindle has thread damage on both sides. Looks like at one time there was a bearing issue that caused damage and the threads have been filed so the nuts thread on OK but the threads are worn down and the nuts wiggle. One side is a worse than the other. I do not want to take any chances with safety on this truck so I need to deal with it. They may work OK but if there is a failure, it could be catastophic with the loss of a wheel.
They don't make new spindles for these that are stock. Only drop spindles are available and I don't want those. So, my options are repair them or find a used set.
Can most any machine shop build them up and re-thread them?
Old 07-16-2013, 07:43 PM
roger1's Avatar
Here's the worse one:
I don't know, maybe I'm being too anal.
Would you use it as-is?
Old 07-16-2013, 07:46 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
That looks shaky.
Any machine shop worth its salt can fix that.
Fact is stranger than Fiction
Old 07-17-2013, 11:26 AM
ogre's Avatar
the 'Duracell Project'
i think your being a little anal, but if you insist...
lots of guys here putting mustII or front clips on their trucks would probably have a freebie for you
Old 07-18-2013, 04:53 PM
roger1's Avatar
Thanks Ogre. I may end up doing a WTB on that forum. I will have to become a contributing member though before I'm able to.
I'm still curious if there is a local machine shop that could build up and re-thread it for a reasonable charge. After I get the spindles pulled, I may go visit one or two.
Btw, here is the other one. I think maybe it's OK because the thread damage is behind the where the nut sits. This one must have had some sort of bearing issue that caused this damage. The nut wiggles on this too but I think I will buy new nuts and see if it's a little more tight.
Old 07-24-2013, 01:00 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
The simplest and Cheapest repair would to buy a metric die (which is slightly smaller (and recut your threads and use a metric castle nut ,it will not be so much smaller that it will cause any problems
you will retain same washer bearings and cap.
Old 07-28-2013, 10:57 AM
roger1's Avatar
After posting my photos in a project thread over on trifive.com, a few good folks there have offered good used ones to me for just the cost of shipping.
I took one of them up on it.
Spark Plug Thread Repair...Success shavdog General Rodding Tech 5 06-05-2011 04:02 PM
I need a spindle for a 47 Ford pickup 1F9O4R7D Suspension - Brakes - Steering 13 09-22-2010 11:17 AM
spindle repair blanch General Rodding Tech 5 11-26-2009 01:56 PM
Front Spindle Repair 49_chevy_truck Suspension - Brakes - Steering 1 10-14-2005 07:49 AM
NPT thread repair tool dawg General Rodding Tech 4 02-22-2005 01:51 AM
