Spindles for '66 pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2007, 08:02 PM
Will a spindle from a '73-87 1/2ton chev fit into the A-arms of a '66 1/2ton chev? I have also read you can bolt in the entire cross arm assembly. If this is true, what are the advantages/disadvantages, and what are the correct camber/caster angles? I would rather just go with the spindles, as all I need to do is add disc brakes. It would save me a few hundred bucks from going to the after-market stores.
thanks.
Old 06-03-2007, 01:32 PM
badriand's Avatar
66 truck front brakes?
Monte Carlo Spindles Interchangability?? texastomeh Suspension - Brakes - Steering 1 09-10-2006 11:09 PM
replacement pickup truck - your advice please jojo99 Hotrodding Basics 7 05-03-2006 10:52 PM
replacement pickup truck - your advice please jojo99 Engine 3 04-28-2006 04:48 PM
replacement pickup truck - your advice please jojo99 General Rodding Tech 6 04-28-2006 01:18 PM
Modified 1958 Chevy spindles Radical1958 Suspension - Brakes - Steering 0 06-14-2003 10:54 PM
