Spindles front, differential rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2009, 12:56 AM
Hi all,
I have so many questions!!!
I have the 1950 Chevy Ambulance with 8 lug spindles and rear axles. I'd like to go with new spindles, 5 lug and a late model rearend.
I believe my ambulance is a 1 1/2 ton. It's at least a 1 ton. Would the standard pickup spindles fit?
also, any recommendation for a late model (60, 70, 80's) differential?
Thanks!
Blanceman
Old 06-14-2009, 09:34 AM
You need to go to THE site for AD Chevy truck questions....Stovebolt.com
Click here
I believe the spindles would swap. HOWEVER, all pickups had a 6 lug wheel. The trick is to put passenger car spindles 49-54 on it for the 5 lug. I do believe that 51-54 (and first series 55) trucks have the same spindle as the car and then you only have to put the car hubs and drums on.
The problem is of course that these are ball bearing hubs not modern roller bearing.
Old 06-19-2009, 06:07 PM
fast68's Avatar
likes chevy trucks & boobies
uhmm
3/4 and 1 ton pickups would be 8 lug
14 bolt FF 10.5 would be the ticket
found under 73-87 years 3/4 and 1 ton
or if you dont want a FF axle then you could go with the 9.5" semi floater
in which are alll 8 lug except for some '88-up 2500 3/4 tons that were 9.5" 6 lug 2wd
light duty 3/4 ton or heavy duty 1/2 ton, whichever way you want to look at it.
are many around,. common here.
but you could probably put these 6 lug axle shafts into an '87-older one if they are the same width
im not sure on widths though.
good luck
Early Ford Spindles fitting early Ford axles pasadenahotrod Suspension - Brakes - Steering 3 08-14-2012 07:20 PM
gear ratios in a 4x4 front vs. rear.... crazy larry General Rodding Tech 3 04-15-2005 07:30 PM
Bel Air AWD conversion k69camaroz28@aol.com Body - Exterior 5 03-30-2005 05:26 PM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
