-   -   spindles upgrade (http://www.hotrodders.com/forum/spindles-upgrade-206680.html)
oldman w/white 57 10-06-2011 01:57 PM
spindles upgrade
I have a Mustang II (Mercury Bobcat 73) Wanted to go with larger wheels, what spindle do I use
oldman w/white 57 10-06-2011 02:00 PM
My mistake
When updated a MustangII front end (73 Mercury Bobcat) What type of Rotors do I need. Keeping wheels Ford
35terraplane 10-06-2011 02:09 PM
Wheels
You don't have to change the spindles, if you want to go to a wider wheel, like 7" to 8", or if you want to go from 15" wheels to 16" wheels as long as the bolt pattern is the same, but if you have a different bolt pattern, say 5" instead of 4 3/4" then you would have to change the rotors or have them re-drilled.
Oh! Welcome to the site.
