spindles upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2011, 01:57 PM
spindles upgrade
I have a Mustang II (Mercury Bobcat 73) Wanted to go with larger wheels, what spindle do I use
Old 10-06-2011, 02:00 PM
My mistake
When updated a MustangII front end (73 Mercury Bobcat) What type of Rotors do I need. Keeping wheels Ford
Old 10-06-2011, 02:09 PM
35terraplane's Avatar
Wheels
You don't have to change the spindles, if you want to go to a wider wheel, like 7" to 8", or if you want to go from 15" wheels to 16" wheels as long as the bolt pattern is the same, but if you have a different bolt pattern, say 5" instead of 4 3/4" then you would have to change the rotors or have them re-drilled.
Oh! Welcome to the site.
Spindles speedydeedy Hotrodders' Lounge 11 12-23-2007 08:45 AM
c4 spindles jts69camaro Introduce Yourself 1 09-24-2007 07:29 PM
Must. II spindles? 41willys Suspension - Brakes - Steering 4 01-29-2005 07:59 PM
m11 spindles 38harry Suspension - Brakes - Steering 2 12-14-2004 03:05 PM
spindles eltigre Suspension - Brakes - Steering 3 05-21-2002 08:12 PM
