Splayed Caps on a 406 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2011, 10:24 AM
I am building a 406, the block will be line bored, my question is should i have splayed caps installed? It will be a steel crank motor about 400+ horsepower.
Old 01-09-2011, 10:31 AM
bigdog7373's Avatar
Of course it's fast
It's not necessary unless it will be spinning faster than 5k rpm. Is it a 4 bolt or 2 bolt right now?
Old 01-09-2011, 10:37 AM
The engine will be expected to turn 6000+ the block is a 2 bolt now. I just thought that with having the block line bored i might as well put steel caps and do splayed caps.
Old 01-09-2011, 12:02 PM
406 bug's Avatar
9.82 @ 139mph
The 2bolt blocks are strong enough to accommodate your use, dont waste your money. You will most likely spend 700 -900 bucks for the caps and machine work. You probably don't need to align bore, a honing of the mains usually all that is required.
Old 01-09-2011, 11:54 PM
ericnova72's Avatar
More for Less Racer
I'd stud and line hone the 2-bolt caps and use it.
If you think that this won't be strong enough for what you plan and are seriously thinking about adding them, think of this - it is a $500 operation in my area plus the cost of the caps(another $100) - when you add that to the bore and hone, cleaning and crack check, deck cut charges, block filler - you are now very close($100-300) of just buying the Dart SHP block, which is tons stronger than even the best trussed up stock block could ever hope to be.
Guys are starting to realize by the time you need to add splayed caps to a stock block... you are right on top of the point you should actually be in a better block...and you are almost there to the cost of the better block in what you have in the stocker. Dart recognized this.
Circle track under 6500 rpm 2 bolt will last a while, 7500 rpm street/strip will live. Internal balance seems to help a bunch.
Old 01-10-2011, 02:05 AM
CNC Blocks Northeast
Before you spend any money in machine work have the cylinders sonic tested!!!
SBC 400... Stud Girdle or Splayed Caps?? Mike1234 Engine 50 02-06-2009 06:18 PM
Installing splayed caps. americanLT1 Engine 6 08-27-2007 08:27 AM
Stock 2-bolt 400 block with splayed caps Mad Maggot Engine 25 10-31-2005 07:32 PM
406 with splayed main caps, maybe a problem? machinist please help. 406 ss monte Engine 11 10-30-2004 10:18 PM
splayed caps BERN Engine 4 01-28-2003 06:32 PM
