Can you take a 4 bolt main 350 block and put splayed caps on it, or will it be weak, where the factory outer holes are? I have a nice 350 4 bolt block, that needs the center caps and didn't know if I could convert it over or not.....any thoughts? Thanks for the help!!!
I believe in order to use splayed caps on a factory block, you must start with a 2 bolt main block and have it machined for the splayed caps. If you have a 4 bolt block, you should use the straight bolt caps. You will need to have it align bored. Hope this helps.
Jeff
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
