Splayed main caps on a factory 4 bolt SBC block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2005, 12:43 PM
Can you take a 4 bolt main 350 block and put splayed caps on it, or will it be weak, where the factory outer holes are? I have a nice 350 4 bolt block, that needs the center caps and didn't know if I could convert it over or not.....any thoughts? Thanks for the help!!!
Old 11-24-2005, 04:25 PM
You can put splayed caps on, but you also can buy stock-style main caps in billet steel. These are plenty strong. Oliver, Callies makes these.
Chris Laarman
Ottawa Engine and Performance
www.ottawaengine.com
Old 11-24-2005, 06:48 PM
I believe in order to use splayed caps on a factory block, you must start with a 2 bolt main block and have it machined for the splayed caps. If you have a 4 bolt block, you should use the straight bolt caps. You will need to have it align bored. Hope this helps.
Jeff
Stroker info ? 421 sbc x007 Engine 16 12-27-2010 09:57 PM
SBC 5.7 Factory Roller Block with Mechanical Fuel Pump? acr Engine 9 11-20-2004 08:05 PM
Two bolt main Big block chevy HTHarry427 Engine 5 06-19-2004 10:23 PM
Where can I obtain factory GM block blueprints? Blownolds Engine 3 08-09-2003 11:47 PM
0.060 over 350 sbc or 0.040 over 400 splayed cap sbc tony350ss Engine 4 05-17-2003 09:02 PM
