Splicing Vac. Line
my Auto Temp. Control vac. connector has broken and i'm fixing to purchase a connector with some line still on it.Whats the best way to splice the vac. tube into the other?
Hi: I'm going to move your post to General Rodding Tech.
Dan
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
Are you referring to nylon tubing?
it may be.. i'm not sure
If the vehicle has hard nylon vacuum line, the normal service replacement is rubber vacuum hose slid over it (splice). The nylon line is still available from suppliers such as AUVECO.
where the line goes to the servo.. it has a rubber thing over it so i guess it is that hard nylon
If the nylon line you need is the standard GM-style hard-line tubing, there are probably lot of cars in the junkyard with what you need. You can also buy new tubing at the auto parts store.
You can splice the hard line tubing with a section of standard rubber vacuum hoses, or most of the auto parts stores also sell a specific piece of line to use for splicing (its sold either under the Dorman brand, or the Help! brand of small parts). I think the small pieces of hose they sell specifically for splicing have a slightly undersized inside diameter and are a little more rigid. That makes it hold the nylon line more solidly. Bruce |
| Recent General Rodding Tech posts with photos |
| vent line | Frisco | General Rodding Tech | 7 | 11-10-2006 03:14 PM |
| Anyone ever had a line lock fail and degrade braking? | sizemoremk | Suspension - Brakes - Steering | 7 | 09-22-2006 02:13 PM |
| vacuum line, what size ? | fat50chevy | Transmission - Rearend | 4 | 06-14-2006 09:43 PM |
| SBC Cooling bypass line question | HotRodF100 | Engine | 2 | 06-15-2002 06:50 PM |
