spline - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2012, 11:31 PM
spline
i am trying to find out if the rear output shaft on a 700r4 is the same as a 4l60e.
Old 06-02-2012, 12:30 AM
327NUT's Avatar
From what I've read yes they are.
Old 06-02-2012, 04:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the splines are the same 27 count for a yoke , if that is the question.
The 700r4 shaft will have a governor gear teeth on it, the 4l60e shaft will not
Old 06-04-2012, 03:13 AM
Wiki Edits: 85
The only difference is that the 700 has a governor gear and the 4L60E does not have a governor gear. Both have 27 splines.
(700R4) 27 spline --30 spline fitment ? vetteman2 Transmission - Rearend 3 02-08-2011 04:54 AM
Change Ford 9" - 28 spline to 31 spline fredbaker Transmission - Rearend 5 09-27-2009 05:12 PM
30 or 27 spline? runn141 Transmission - Rearend 1 10-06-2007 08:43 AM
27 or 31 spline in 8.8 Can drive 55 Transmission - Rearend 1 11-23-2005 07:29 AM
what spline? jo5hi3 Transmission - Rearend 2 07-17-2003 09:10 AM
