Splined steering shaft for 40 Ford column - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2006, 09:53 AM
Last journal entry: Bringing home the 401 Nailhead
I have a 40 Ford steering column, wheel and shaft in my 32. I am changing the steering box and need a splined or D shaft. Anybody make a steering shaft that is tapered w/woodruff key on one end and splined or D on the other?
Old 12-01-2006, 10:09 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Check with Borgeson....they have all kinds of shafting as well as couplers and adapters etc. www.borgeson.com
Old 12-01-2006, 11:31 AM
Thanks Henry...Should have mentioned that I have already talked to the large suppliers. Tech at Flaming River says they have a billet column with shaft but won't sell just the shaft. I am really reluctant to swap out the whole column if I don't have to. Might just have to buy a splined shaft and turn down a taper on one end.
50 Ford Tudor Pwr Steering Conersion Schenkeinstein Suspension - Brakes - Steering 5 01-29-2010 04:58 PM
37 Ford Pulling Steering Wheel 37FordCoupe Suspension - Brakes - Steering 12 01-28-2007 04:25 PM
30's Ford steering column bearing? Kruzin Karl Suspension - Brakes - Steering 2 11-27-2006 02:39 PM
1986 s-10 truck steering shaft linkage worn? fumplet Suspension - Brakes - Steering 4 07-21-2006 10:42 PM
What steering column to look for... Nightfire Suspension - Brakes - Steering 2 06-28-2005 07:32 PM
