split wishbone - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2012, 07:02 PM
split wishbone
can anyone advise on the best type of ends to use on a split wishbone for a model a? Wondering if I should use rod ends or 4 bar ends. Tie rod ends?
Thanks
Old 05-08-2012, 07:13 PM
BOBCRMAN@aol.com's Avatar
Tie rod ends last longer. Urethane bushings ride better. But hard to find with correct angle. Speedway sells 7 degree ones that work well on a new fabrication.
Old 05-08-2012, 09:23 PM
I have a Chassis Engineering split wishbone kit under my 36 roadster and it comes with tie rod ends. It certainly is easy if you are going to split your stock wishbones. I have been pleased with the set up.
John L.
Old 05-08-2012, 10:39 PM
split wishbone
Thanks guys,sounds like tie rod ends is the way to go.
Wishbone question??? Kevin1938ford Introduce Yourself 2 10-10-2009 11:10 PM
40 Ford rear axle on a 32 frame with split wishbone. Huskinhano Suspension - Brakes - Steering 8 11-09-2007 08:07 PM
split wishbone with crossstear k-9cop Suspension - Brakes - Steering 2 07-22-2004 11:10 PM
