Splitting front brake lines. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2007, 10:08 PM
Trying to do my front disk conversion using 100% new parts.
Ok i cant use the combo valve anymore because that is set up for drum/drum.
So how do I go about splitting the front brake lines?
Can I just use a "t" fitting from say NAPA? or am I going to be forced to spend $130 on a new distribution block?
Old 02-17-2007, 11:56 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
I would ask the good folks at Engineering Components Inc. why you can not use the existing lines.
Old 02-18-2007, 12:10 AM
powerrodsmike's Avatar
Wiki Edits: 161
If you are doing a disc conversion up front and leaving the drums in the back then you should either use a combination valve for disc/drum or use a metering valve in the front line and a proportioning valve for the back.
ECI sells a stand alone metering valve for about 85.00
Here is what one looks like .
If you are doing 4 wheel disc, then just use a "T" that is designed for use with the tube you are using.
Later, mikey
BE different....ACT normal.
Old 02-18-2007, 01:10 AM
solidaxel's Avatar
Later, mikey
So what is the difference between the one he has in place and the one that ECI sells? Is a Combination valve a combination valve, what is the difference?
Old 02-18-2007, 01:20 AM
Wiki Edits: 161
A combination valve for a drum/drum system may have a rear proportioning valve and a switch to hook to your brake system warning light.
It has a splitter for the front lines but no metering valve.
A combination valve for a disc/drum system also has a proportioning valve for the rear, the warning light switch and a metering valve.
The metering valve keeps pressure from reaching the disc brakes until the rear brakes have started to activate. Usually between 10 and 40 psi, but I have heard of 100 psi.
The reason is that disc brakes will activate at low speeds with less pressure than the drums will. So, without the metering valve, the fronts will do all of the work at low speed.
I have driven cars without the valve and had the fronts lock up first in wet or slippery conditions. It can be annoying and possibly unsafe.
You can read what ECI has t say about those valves here
http://ecihotrodbrakes.com/brake_facts.html
Later, mikey
Old 02-18-2007, 04:55 AM
Wiki Edits: 31
drum/ drum will sometimes have residual preassure valves, right in them, which would cause brake drag on disc brakes.
Old 02-19-2007, 08:53 AM
Later, mikey
Ok i understand what you are saying but with a 10lb residual valve installed in the rear lines there will allways be 10psi in those lines right?
So the rears should activate a little before the fronts right?
Old 02-19-2007, 09:05 AM
Wiki Edits: 161
No, the 10# won't have any effect on the rears. It only keeps enough pressure to have some preload on the return spring so you don't use any more pedal travel than you need to.
Most rear brakes require 20 psi or more just to overcome the return springs.
That is why a disc/drum system needs to valved with a metering valve.
Pressures in brake systems can reach 500 or 600 psi just in normal use. A panic stop with a power boosted system can develop well over 1300 psi. 10# won't make a big difference in the activation of the rears, other than the travel at the pedal. You could say that 10# valve takes up some slack..
The link to ECI that I put up there explains the function of the valves also.
Later, mikey
Old 02-19-2007, 09:14 AM
I am definately not psyched about having to spend an additional 85 dollars on this project...
Old 02-19-2007, 09:30 AM
Wiki Edits: 161
I'll have to say that going cheap on brakes is a poor choice. To some, only money matters.
You can run without the metering valve, alot of people do.
Going without it will make your front brakes do all of the work at low speeds.
I wrote in post 5 that it could possibly be unsafe in wet or slippery conditions.
If you had ever driven a car in wet or slippery conditions that did not have a metering valve, (I have), you would realize that 85.00 would be well spent.
There is a reason that almost ALL OEM disc/drum setups have that valve.
Knowing all of that should help you make your decision.
Later, mikey
Old 02-19-2007, 02:15 PM
solidaxel's Avatar
I guess the PUCKER factor is not worth $85.00!!!!!!!!!!!!
Old 02-19-2007, 07:21 PM
Someone just stole my bank account information today and has been making fraudulent purchaces so the new meetering valve is going to have to wait for a little while.
Thats ok, I cant drive the car until spring anyway.
Brake Lines for 1968 Chevy SWB 68chevytrkr Suspension - Brakes - Steering 2 10-03-2006 03:34 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 02:29 PM
brake lines next to headers 49dream Suspension - Brakes - Steering 4 04-22-2006 06:24 AM
Braided brake lines garbock Suspension - Brakes - Steering 4 01-10-2005 09:56 AM
Brake lines how often should they be replaced? Jag Daddy Suspension - Brakes - Steering 1 03-18-2003 05:56 AM
