Originally Posted by wma1950
when carb is at WOT i cannot get any clearance on shaft no matter what i do. i have turned it up until spring was collapsed with no give and still can't get gauge to go between shaft and adjuster linkage. and when i go the other way it just gets tighter.
I really do appreciate the info. I have been able to use most of it. This carb may find its way to the lower 40, if you know what i mean. It just tears me up though for something to beat me. sometimes i need to quit but won't. LOL
Are you able to take a couple photos of the carb, showing the acc. pump/linkage? Or can you compare what you have to a photo of another 3310 to see what the difference is? It is probably nothing that cannot be fixed- and fairly easily I would imagine. Not making light of your problem, but there are only a few things it can be, like a part mis-assembled or a bent part or a bad adjustment... that sort of thing.
Is there a chance you have a 50cc pump on it w/the 30cc linkage?
30cc pump diaphragm, cover w/pump arm
Late style plastic linkage/adjuster screw assembly for 30cc pump
50cc pump diaphragm, cover w/pump arm, linkage specific to 50cc pump assembly
