spool setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2011, 01:10 PM
spool setup
I have an 8 3/4 Chrysler limited slip rear end that I am going to put a spool in.
I would like instructions for setting up the the proper gear lash.
Thanks, Ron
Old 01-24-2011, 01:27 PM
big gear head's Avatar
High Performance Rear Ends
This should answer most of your questions. http://www.nastyz28.com/forum/showthread.php?t=19773
New spool - Need help S10 Racer Transmission - Rearend 2 04-25-2010 09:25 PM
spool vs. mini spool 72fordlb Transmission - Rearend 7 11-14-2009 03:44 PM
Full Spool or Mini Spool??? S10 Racer Transmission - Rearend 1 04-02-2008 07:50 AM
difference/pros/cons of spool and mini spool? "70" Cougar Transmission - Rearend 20 03-03-2006 11:42 AM
What's a spool and mini spool? 84Z Transmission - Rearend 2 01-31-2005 08:33 PM
